svairman »
https://forums.nicoclub.com/svairman-u50389.html
Wed Jul 07, 2010 6:59 pm
I've read some past threads and been searching a bit but haven't found anything conclusive or anything that has been followed up on. Is it possible to bypass the FPCU and run an aftermarket pump with with the same flowrate? I figure you'd want to use a pump with the same rate of flow as the highest setting, wire it in using a relay and figure out a way to securely mounting it in the take keeping the location as close to factory as possible using a similar style strainer. My only concern is with the pump running at full pressure all the time instead of the three setting like the stock, that at idle and partial throttle the fuel map will be two rich. I'm basing that assumption on the idea that the pump runs at a lower rate while at those two conditions. Is this correct and has anyone else successfully tried this?
I'd probably go with a walbro unit, I know they're less expensive but I've used them before in the past on both my turbo charges LS and lightly modified SR with no difficulties or reliability issues.
