got it thx please delete
preston240sx
Car: Nissan 240SX S13
got it thx please delete thread
StricNyne
only thing that could happen is 1 you didnt reinsert fuel pump fuse when you cleared the pressure, 2 the regulator is set for 0 psi, or 3 the regulator is backwards in which case it should still work just very s***
preston240sx
well the pump is flowing plenty of fuel it humms when i turn the key on in the 3rd pic i turned the key on its showing like 50 psi ... its just werid that it will run with the oem fpr hooked up with the other one hooked up but when i hook the fuel rail adapeter up and pull the oem fpr it just cranks over....
