http://www.hoen-usa.com/city2.htm wrote:A couple people recommended these:
Höen city light bulbshttp://
The Hoën W5W city light is designed to produce 4,100k perfectly matching your HID low beam lighting. Generates a surface temp of 100º versus 85º of factory bulbs. Recommended where adequate area around bulb is available for cooling and no plastic parts touch the bulb. For a low heat generating option with a slightly whiter light output we offer the LED below.
City light W5W fitment also cross referenced as the 2825 (Osram) 158, 168 and 194 fitments.
W5W city light4,100k$12 per pair
Optional LEDNot all W5W LED's are created equal. When customers requested such a bulb from us we turned to the worlds leading supplier of solid state LED's to design a radial light emitting (RLE) specifically designed to throw light in all directions.
In the image below you can see from a side angle shot the Hoën bulb outperforming the leading 3w LED design by a wide margin. This translates into the most accurate light projecting W5W LED available without the Achilles heel of traditional LED bulb designs narrow light beam.
Recommended for installation in HID low beam equipped vehicles only. Due to low power consumption may trigger bulb out lamp on cars equipped with this feature. Radial city light is 2mm wider than standard W5W, please measure your housing to verify it will fit. City light W5W fitment also cross referenced as the 2825 (Osram) 158, 168 and 194 fitments.
W5W city light radial LED4,200K$12 per pair
