Aftermarket Flywheel Dilema
SHiFT
Well I've been searching the archives for aftermarket flywheel reviews. There seem to be many mixed opinions about getting one. I'm going to put a new clutch in soon, Spec Stage II, and am wondering if it is really worth it to spend $300 or so for a lightened flywheel. I know you have to resurface the stock flywheel if you don't get an aftermarket, how much would that be usually? Basically this would be for a stock KA with a few bolt ons, maybe nitrous if I feel like it, and in a year going turbo. Mostly though it would be a daily driver. I am kind of on a tight budget, so I'm just wondering if the lightened flywheels are worth buying while installing a new clutch. thanks all
p00t
well usually a lightened flywheel allows u to rev slightly higher and faster.
you will lose some power when beginning to accelerate because you will have less rotational intertia.
IMHO, daily driver + low budget = save ur pennies for the turbo set up! there will always be extra things you wind up buying with a turbo setup, better to not botch up the install.
SHiFT
yeah good point, I'm not going to get the flywheel. Thanks.
trpower7
There are mixed reviews about it all over the place. I don't think it's a good idea for a KA, as the KA is better suited to low-revs. Re-machining your current flywheel is about $45.
