aftermarket floor panels???
Sky240PWR
Car: 1991 Nissan 240SX
mine is rusted and I need to know if there's a company that sells floor pans for a 91 hatch........or do you have any ideas?
RedRum240
Car: 1990 240sx Fastback
um yeah take a torch and torch out all the rusted part. then weild a piece of alluminum across the whole part with the whole. simple. cost you like less then 40$ probably
kouki munster
Car: 97 base 240
I don't know of any where you can buy them, but you can use some sheet metal to make a patch for that hole.
574-240sx
Car: Nissans, Toyotas, Subaru
Cut it out, gring the rust and some of the paint off then weld some sheet metal in, then paint it. If you don't have any experience I would seek somebody who is good at welding and has access to all the stuff you need.
Sky240PWR
well, I'm not doing the work, my body man is. He told me to either find another 91 hatch and cut the floor pan I need or find some aftermarket ones. I remember I bought some for my 79 trans AM years back...lol
lenso
Car: 1993 240sx hatch
RedRum240 wrote:um yeah take a torch and torch out all the rusted part. then weild a piece of alluminum across the whole part with the whole. simple. cost you like less then 40$ probably
you can't weld aluminum to steel...
574-240sx
most floor pans will look like yours from the north, better off just welding something in after you cut the sheet metal to size. Maybe someone from the south will cut you some floor pans out of a rustless car.
S-13KA
Car: Several
If your floor looks like this are you sure your sub rails are in any better shape?? You may want to put it on a lift and give the whole uncarrage a real good going over.
ragenasian
Car: AE86 w/CA18DET
Do what Mr. K said. I did the same thing with my Suzuki Sidekick and it passed the very strict German inspection. Just treat the rust you already have, weld, and put on some kind of rust prevention paint over the fix (por-15 or something like that). I also sealed the whole repair from the bottom of my fix with silicone to prevent anything getting into the space between the patch and the old metal because there should be overlap to make sure you weld to good metal.
Sky240PWR
my body man has already put it on a lift and checked it out, he said thats the floor pans are my only problem.
