Postby
boxcarbill »
https://forums.nicoclub.com/boxcarbill-u75360.htmlFri Sep 10, 2010 1:41 am
When is someone gonna make a replacement final drive (ring & pinion) so I can get some more overdrive on my '07 6 speed? I guess I'll have to lower the first gear ratio also for it to work. I'm only dreaming.
Promise Land wrote:all it takes is money. someone just needs to go get it done.
The parts already exist?
I want to raise my final drive ratio by 20% (I'm already getting 8% with oversize tires)
and lower the 1st gear ratio by 25%. That should work.
