Aftermarket driveshafts? Aluminum?
Spade
Car: Cars
Is there a company that makes aftermarket drive shafts for the S13/S14 240s?
240SXedUp
Bandit240
Car: 1980 Datsun 720 King Cab
hmm i might like to buy one of those. IVe been wonder if anyone made a 1 peice driveshaft for the 240SX
240SXedUp
Ya, i dont recall any bad results with it. I dont have one tho so i cant speak from experience
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i forget where but ive seen a 1 piece carbon fiber driveshaft for the 240sx. ill remember the web site sometime im sure. it wasnt all that expensive either to tell you the truth..
- tim
TurboKA37
a carbon fiber driveshaft for the 240?? nice. ask Exar-Kun (a mod in suspension forum) about the aluminum driveshaft from enjuku. he has one
r34 gtr
http://www.pstds.com/carbonfiber.cfm
they dont have one for the 240sx, but at the top of the page they say they will make one for you if you give them the specs you need. they only go to about 1200 bucks max, so they arent that bad.
- tim
TurboKA37
too much for me, but it sounds like a really cool product!
Cyberkreig
Car: 1993 Nissan 240SX SR
i have an enjuku one.. in a box. 2 more weeks probably.
TurboKA37
i imagine theres a pretty good wheel hp gain from using the aluminum driveshaft. id like to see a before and after dyno to see how much it helps.
Cyberkreig
I'm adding a J30 diff at the same time, So i unfotunatly wont be able to get a true butt-dyno.
civics91
Car: cars,cars,cars
i love mine it fits real good but i dont know about driving
TurboKA37
you dont kno about driving? does that mean you havent yet driven the car with it installed?
ride4lame
ok 3 questiona, if its a one peice...does that mean it has no u-joint? 2 IF thats right doesn't that make it a huge pain in the *** to take it out/put it on? 3 What are the advantages to 1 peice?
240SXedUp
Quote »Enjuku Racing Aluminum Driveshaft for Nissan 240SX w/ABS, 95-98. This is a one piece lightweight aluminum driveshaft for the S14 240sx and SR20DET powered 240sx. It eliminates the 2 piece, heavy steel stock driveshaft. Weight on this driveshaft is only 11 lbs! Reduces rotating mass and is significantly stronger than stock. As an added bonus, the stock driveshaft bushing support can be used as a driveshaft safety loop. [/quote]
Ive never really installed or been around driveshafts, but 11 pounds seems rather light IMO
ride4lame
informative thanks... but isn;t that a beotchpain to get out and put in? (ie drop trans or diff?
Cyberkreig
all you have to do is unbolt it from the diff.
spitz7985
Car: HICAS S13
dropping the driveshaft is easy
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
which one would be stronger the cf one or the aluminum one?
civics91
Car: cars,cars,cars
i would say about the same the cf will twist up when dump the clutch
TurboKA37
the cf will twist when u dump the clutch? i highly doubt that. the epoxy resin in the cf driveshaft is very hard and stiff.
JDM
Car: Import Cars, Powerlifting
I think carbonfiber is stronger, but you may want to check it out. The main benifit of carbonfiber is that if the driveshaft were to break it would become like a broom causing little damage compared to a big metal rod. Carbonfiber is also lighter, but more expensive.
TurboKA37
CF really isnt lighter, its just much stronger which means you can use less material. less material=less weight
JDM
Thats what I was trying to say... That the driveshaft as a whole would be lighter.
Cyberkreig
I'm willing to bet that a CF driveshaft will bend, as far as i know all driveshafts twist to some extent... when talking about sticky tires and large amounts of HP
BoostFab
Car: S13cp, S13fb, S14z
r34 gtr wrote:http://www.pstds.com/carbonfiber.cfm
- tim
dang; 1200--that's the cost of a freaking rb20 clip
Aries
Car: LT1 240SS
Cyberkreig wrote:I'm willing to bet that a CF driveshaft will bend, as far as i know all driveshafts twist to some extent... when talking about sticky tires and large amounts of HP
I'll tell you this.I broke 3 aluminum driveshafts under my car.THen I put in a CF one.Haven't broke it yet, and have nearly double the hp that broke the previous ones.
ricebike
2002 Quest
2005 Altima
i'm just having brain freeze w/ this cold climate...
Y didn't the engineers just use a single piece driveshaft for these cars in the 1st place/ y involve a 2-piece w/ a carrier bearing?
Tastyratz
Car: 240sx
aries, how much power were you making when you broke them?
Redline240
Car: 95 240sx
Tastyratz wrote:aries, how much power were you making when you broke them?
I think the better question would be how many ft/lbs...he is running a V8 remember and slicks....the factory driveshafts seem to have no problem holding up to 400+ ft/lbs on street tires...i would assume the aluminum one would withstand that and more...
Redline
