If the target spec is 10 deg BTC, 15 is off, but I honestly don't recall what the spec is and all of the specific conditions for checking the timing.yodawill2000 wrote:Oh yeah ..Is 15 degree's BTC timing at idle way off ??
Wait you got that adapter for $28 while he charged me $44 and he said that was the discount.yodawill2000 wrote:here's the rig.
http://cgi.ebay.com/ebaymotors...88131
FYI that usb adapter shown is NOT included.Im gonna go try the 6 dollar cable adapter that didn't workbut I was plugged into the wrong port.The cablemax adapter shown has the ftdi chipset which Jason said works the best. about 28 bux shipped.email me at [email protected] and I'llgive ya the inside scoop.
Modified by yodawill2000 at 7:08 AM 9/27/2008
OK, I've got a light grey connector that's located just above the brake pedal and connected to the same bracket as the door lock timer. I'm using a $14 USB to serial port adapter cable and need to ID the comm port.yodawill2000 wrote:Pretty simple actually.Find out what comm port your computer see's as the USB adapter.Set that as the comm port in the software.Then click ECU finder.Not sure what version it is.Just named Emance consult.
It looks like things should work with it set up to access COM 8 via the USB cable.GerryO wrote:
OK, I've got a light grey connector that's located just above the brake pedal and connected to the same bracket as the door lock timer. I'm using a $14 USB to serial port adapter cable and need to ID the COM port.
In terms of interior disassembly it's probably easier to access the ECM than it is the Consult connector and so far nothing is detected, but I got a late start this afternoon.
Any other hints/suggestions?
Thanks!
i thought 93-95 were OBD 1 and 96-97 were OBD 2xxcrashxx wrote:since were on this topic, anyone on here have an iphone or ipod touch and checked out the program called rev lite??? on their site, they say you can get a 802.11 wifi adapter that will connect to your ODB II port, and it allows the iphone/itouch to communicate with the ECU, and give you readouts and important crap like that... however, on their site, they didnt list any specific devices to purchase that are compatiable. anyone know if theres any devices that will connect to a '95 j30's ecu, that will give it wifi posibilities???
