Aftermarket CA pistons
boost_boy
For you guys trying to save a buck, I understand you. But when it's something as critical as a piston, the difference of $50-$80 is not worth the headache you'll get if you don't make a wise decision. I personally have wieco pistons in my built engine, but again, they are modified and I recommend against you guys doing that. For most of you, you shouldn't be screwing with the pistons anyway if nothing is wrong with yours. If you're not expecting to exceed 500whp, leave the stockers alone unless you've worn-out your bores and then they'll need to be re-bored. If you guys don't pay attention to the advice being given, you'll get frustrated and you too will be selling your stuff to a low-baller. CP pistons for you high HP dreamers and for you guys that just want to clean-up your engine, re-ring, hone, clean and re-install the stockers.
Dee
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
^ Can I have that stuff in the picture? For free?
boost_boy
r34 gtr wrote:^ Can I have that stuff in the picture? For free?
No! Bum .
Dee
RM12577
Car: 89 Nissan 240SX with CA18DET
94 Nissan vert in need of work
So wiseco just made the pistons wrong and they have to be modded to work correctly with the oil squirters, right? That answer might help people to not get them if they know the reason not to get them, but if I remember correctly from reading too many posts while I sit at work all day it was an oil squirting in the wrong place not cooling right thing... and if that is true then the CP pistons are shaped correctly? just making sure people are clear on it, that is saying that they read this though, sometimes I wonder if some of the people that post can really read....
r34 gtr
They didn't necessarily make them wrong, they made them for the N/A FWD CA18 which did not have oil squirters.
zil40
Car: 89 240sx
they made more than one set some people got the right ones others like me got the bad set i waited about a year to get the right ones but wiesco didnt help so i used them with out the sq and its fine so far
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
the reason i plan on going aftermarket pistons and rods are because i like to keep my options open, and if im going to tear into the engine, i mind as well replace the pistons and such with **** i know will last. while the reliability is good on the OEM internals, can you blame a person for going forged? im shooting for 350whp - 400whp, but after that, who knows what i'll want to do with it?
zero_gripS13
Car: soon to be 95 s14 hopefully
my **** had a blown head gasket and the cylinder was rust pitted, and 3 pistons have cracked ringlands.. so yea i was up ****s creek without a paddle.so i went cp and 84mm bore to get me going. stock rods with arp bolts. that setup should be fine for up to 500 reliable with the right tune.. i wouldnt trust the rods past 500whp. the most this engine will probably see is 350whp.. i just hope i dont have any problems.. im investing alot of moeny into this and hate to have something go wrong .... so well see
HighwayStar22
Car: 2002 RSX Type-S, 1991 240 Hatch
So would now be the wrong time to state that with uprated pistons, you really don't need oil squirters until you get to extremes?
sjbsuperman1425
CA18DET
HighwayStar22 wrote:So would now be the wrong time to state that with uprated pistons, you really don't need oil squirters until you get to extremes?
this has been going around like herpes right now lol its been talked about in another thread as well. CP Pistons FTMFW!!
