SteveTheTech »
https://forums.nicoclub.com/stevethetech-u103802.html
Sat Jun 06, 2009 9:32 am
Be sure to lube them using a high quality grease. Use the factory shims they will make a difference, even the cheapest aftermarket pads usually have a backing plate that corresponds to the tabs on the pads.
The noise frustrates enough people that the majority of noise complaints I see (involving aftermarket pads) usually ends up with the purchase of a new shim kit to resolve this issue. A little extra time in doing this procedure will yield much better results in the long run.
A freshly cut non directional finish on the brake rotor face will also make a big difference in feel and ensure proper burnishing operation.
