Aftermarket bov on a stock SMIC?
smokey240sx
I have a complete stock SR SMIC and all the piping. Do I have to disable the stock recirculating valve on the intercooler?
S13240
YES
smokey240sx
will capping it off be good enough?
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
yes.
TogueDrifter
Car: 91 B13 SER
Is a aftermaret BOV really neccessary for the stock setup? won't affect performance will it?
Pepperoni
stock BOV will start leaking at or above 10psi on stock turbo. so yes, it usually is a good idea to get another BOV unless you want to modify your stock one.
S13240
Pepperoni wrote:stock BOV will start leaking at or above 10psi on stock turbo. so yes, it usually is a good idea to get another BOV unless you want to modify your stock one.
Funny you said that because my first s13 held 14 psi easily on stock bypass valve.
Then the s13 I have now has what you're describing. I had an Apexi Twin Chamber on the first couple runs I did out at Fontana this year then just last week I went back out to Fontana with the stock bypass valve installed and I ran 4 mph slower than the usual but still doing the same times...odd.
Anyway I think it really depends on the condition of the bypass valve if it will hold more than 10 psi or not.
Pepperoni
Interesting. Good point - the BOV's condition probably has a lot to do with it. Mine definitely leaked past 9psi (i could hear it + dyno checked out) as well as my friend's over ~11psi.
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
id block it off and get an aftermarket if you have plans to up boost, and if you plan to get a FMIC in the future
ca18det_boy
yeah just cap it off, you shouldn't have any problems
drifter_for_life06
Car: Daily: '16 WRX
Exocet
ca18det_boy wrote:yeah just cap it off, you shouldn't have any problems
provided he caps it correctly
ca18det_boy
c'mon man, your trying to make this more difficult than it has to be. It doesn't take an engineer to cap something off........
574-240sx
Car: Nissans, Toyotas, Subaru
ca18det_boy wrote:c'mon man, your trying to make this more difficult than it has to be. It doesn't take an engineer to cap something off........
On NICO anything is possible
drifter_for_life06
Car: Daily: '16 WRX
Exocet
i know its not hard, just saying, in the 240gen, there have been some compelte idiots posting liek its rocket science doing simple stuff......take the guy wanting sleepy eyes for instance
ca18det_boy
LOL ok yeah, I'm not saying that there isn't people who don't deserve a kick in the junk. I'm just trying to give credit until its proven that it shouldn't be given.
smokey240sx
thanx for all the replys. give me some credit. i'm not going to use a large bottle cap and chewing gum. .
drifter_for_life06
Car: Daily: '16 WRX
Exocet
you get the credit you deserve, more then most
if you used a bottle cap and gum, i would laugh hysterically to the point i literally might die
smokey240sx
you'll see it at the next meet around HBG. If you die from the sight of my ghetto intercooler cap could I have yours?
S13240
I actually cap mine off with a bottle cap everytime I decide to install my Apexi twin chamber. It works and still looks clean. Function over form sometimes.
Neil
Car: shooting laser guns
fwiw when I got my smic, the stock recirc leaked VERY badly. capping off the exit and blowing into the inlet of the intercooler you could plainly hear it leak. i wanted a greddy rs and nice hotpipe so i was already planning on disabling the stock bypass valve, but then it turned out i had to anyway. dont know what's in 'em but it wears out after 15 years.
Greddy RS is nice sounding... out of the box plug and play it seems to be set up perfectly for 7psi. no bogging problems between shifts either.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I just installed my Greddy RS Valve And i love i.But im having a hard time getting it to open at 7psi.Im getting some surge.I have the hard and soft bolt all the way on soft and still.Guess its time to raise the Boost! 9-10psi sould do it.
Neil
Make sure the BOV gets its own dedicated vacuum line... i ran mine to the fatter of the 3 lines on the tb. The blue hose they provided was a little small for that fitting (and my tastes) so i bought some the right size but then it was a scoche too big for the BOV. used a teeny hose clamp on the bov and everything works perfectly. If you turn up the boost and the BOV isnt seeing proper vacuum when the throttle plate suddenly closes, youre just going to get more compressor surge.
