I
Pwnin O’Brien wrote:It takes a LOT of turns and you can't physically see the lamp move. It literally takes hundreds of turns to see a change. I recommend using a power screwdriver or drill with a phillips head bit.
I seriously doubt that this is possible, if it were true, the amount of threads on the adjustment screw would be more then 10,000 threads pr inch.....that just isn't possible unless they used some sort of partical laser on some sub-atomic level to create such a thread pitch. Its more likely that the adjustment screws are for asthetics only, and in order to aim the lights, you need to take a trip to the hard ware store, and buy about $10 in small rubber washers and use said washers as shims. It will be a long painful process to correctly adjust the beams this way, but I don't see any other option. I plan on retrofiting some projectors in my stock beams, and spraying the factory housings black....That will eliminate any forseable adjustment problems.
JT
