Aftermarket alarm HELP
Neo2020
Trying to install a soundstream ars2 alarm/remote start. Factory alarm still installed and connected. I cannot for the love of nissan figure out what door lock wires go where. Input PLEASE! I have both wiring diagrams if anyone can put it together. The alarm also has 2 red 12v+ wires. Should these both be connect to the white/purple ignition switch wire? I have listed what I have installed so far in BOLD and underlined.
Constant 12V+ White/Purple Ignition Switch Harness
Starter Black/Yellow Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Ignition 2 Red/Yellow Ignition Switch Harness
Ignition 3 Starter 2 Red/Blue or Black/Green Ignition Harness
Accessory Red/Yellow or White/Blue Ignition Switch Harness
Tach Blue or White Coil
Neutral Safety Wire Black Gray 2 Pin Connector under Shift Selector
Brake Switch Green/Yellow Brake Switch
Trunk Release Light Green/Red (+) Rear Hatch Switch
Parking Lights Pink/Blue (+) Security Module right of Column
Head Lamp Red/Green (Driver's) Red/Black (PAS) at Head Light Switch
Hood Pin Yellow/Black Security Module
Factory Disarm Light Green (-) Security Module or Disarm with Locks
Door Trigger Red/Black (-) Security Module right of Column
Door Lock Yellow (-) Security Module right of Steering Column
Door Unlock Light Green Double Pulse (-) to Unlock
Driver's Lock Blue Right of Steering Column
Driver's Unlock White/Purple Right of Steering Column
Passenger Unlock Yellow/Black Right of Steering Column
Horn Wire Light Green/Black (-) Steering Column
Windows Up LF=Blue/Black, RF=Blue/Yellow, LR=Red/Black, RR=White/Black
Windows Down LF=Blue/Red, RF=Blue/White, LR=Green/White, RR=Black/White
ALARM WIRING BELOW
https://security.soundstream.com/manual ... nstall.pdf
