Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Wed Feb 20, 2008 2:28 pm
I don't know if it says anywhere in particular that you "need" to, but common sense should tell you that at some point in the life of the car, the air filter will get dirty, and needs to be cleaned or replaced. The point of the K&N is that it is reusable. There is a cleaning kit that you should have. You can buy it at any auto parts store. The filter is soaked and then washed in their solution, and then you let it dry. If washed properly, the filter will not be red anymore. The oil and dirt should all wash out. Once it is dry, then you re-oil the filter. That's where the red colour comes from. Just be careful. Don't over oil it, and let it sit for a few hours after you do it, just to let it evaporate and dry a little.
