Also check the throttle position sensor connector. It will be a black connector similar in size to the MAF connector but attached to the TPS on the throttle body at the opposite end of the air tube. Do the same pin cleaning and tightening as described for the MAF connector.BlackMajik wrote:Yes it does start normally and after pressing the accelerator a couple of times...
