My dilemma started when I stopped working on it myself and took it to a shop. Due to a hectic schedule and a lack of time I did my homework and found a shop whose nissan man has 10+ years working on Z31s and 32s. I had him do a 120K tune up.
The problem: I've put 10 miles on it since the new timing belt and tune up and it's shut off on me three times, the last forcing me to tow it in. After speaking to the mechanic he said it must be a fuel or spark issue, not knowing that I replaced the plugs with NGK, replaced all new injectors, coil packs, all connecting clips, belts, angled cam sensor, MAF sensor, coolant hoses, vac lines, fuel pressure reg, fuel filter AND pump. ALL parts throughout the entire project have been replaced with OEM parts from Z1, with exception to the MAF-reman from NAPA. Everything was replaced prior to the 120K tune up, nothing afterwards. After the 120K; Cranks fine, idles seemingly normal, but when I try to give it gas it hesitates but between 2500-3000 rpm it runs fine. Slowing to a stop it idles rough as hell. On three occasions it idled to a stall, each time harder to restart with the last having to be towed. Now, when turning ignition to on, fuel pump primes like it should and it turns over like it should but it doesn't crank.
Thought's?
1st Question: Has anyone experienced this problem post 120K? Or do I have reason to believe the timing belt job wasn't done properly?
2nd Question: Before this last time it took a dump; I was able to pull over and pop the hood to watch and hear it stutter. Frustratingly I looked at it like
3rd Question: Any chance it could be the IAC?
Kick some ideas around with me. Thx
