after the sr20det swap.....
tony/ka24de
After the sr20det swap I have realized that my heater control on my dash will not switch positions.(eg. top defrost, vents,and bottom). Has anybody had this problem? Does anybody know where all the wiring is for it?
SpeedRacer1
Car: 1990 240SX, G35
You probably blew that fuse out, I did that awhile back too. The fuse is one of the ones in the driver side interior fusebox, check there first before ripping everything apart.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
Mine did the same thing, its more than likely just your fuse. That was my problem
tony/ka24de
i have checked the fuses. Its not that. I think its a wire I cut or didn't connect at the right kick panel
SpeedRacer1
None of the wires at the right kickpanal have anything to do with the heater controls.
tony/ka24de
maybe not with the heater controls, but maybe the main power for the mode switch is cut somewear, It has to be somewear on that side, it happened after the swap
