FarFetched »
https://forums.nicoclub.com/farfetched-u25415.html
Fri Apr 08, 2005 6:25 pm
I suspected faulty MAF, also batt was a biot weak. So, I replaced both.The car (97 Q45) still does the same. Intermitten stumble at idle and hesitation at very light throttle (variuos speeds) just before transmission kicks down! It seems to happen when TCC locked up (i can see slight RPM drop). Dealer said that they might spend entire day diag this problem and never find anything because there is no MIL light or any codes that I know of!
I read an article (web site) regarding hesitation!Here it is!Quote »Hesitation has been decribed by several auto owners as a surging of power or a hunting for power while attempting to accelerate in a smooth fashion. The car lunges and hesitates all while the gas pedal is being pressed ever so gently or even held in one position. The car can't seems to find a place where it wants to take off smoothly. It seems to hunt for a sweet spot. It feels like it may be starving for fuel, air, or spark.
In the case of my car's problem, the hesitation felt was this:
The ignition advance that normally occurs during accelereation was being hindered by engine management, the computer. The computer was hearing some noise through the knock sensor that it had interpreted as engine pinging. The engine was not pinging, but try to tell my computer that!
So the result was varying degrees of ignition timing advance during acceleration. Everytime the ignition advanced, the power surged and every time the ignition retarded, the power level fell. [/quote]I appreciate any input!Thanks?!
