people swap manual ecu for auto all the time for it not having a speed limiter and having a slightly higher revlimit.and im pretty sure thoes guys dont have to swap tps.so that shouldnt be an issue.mr_wizard wrote:Auto and manual TPS's are different too. Make sure you've swapped those sensors. I'm pretty sure you need a manual ECU though. Someone back me up on this
yeah, im sure that auto ecu eliminates the speed cut. do a search if you want to know for sure.hmm i coulda sworn ive read that its a straight swap, meaning just replace the ecu's and be done with it. but i guess im wrong about that.mr_wizard wrote:TPS's have to be swapped, that's a fact. They are different. Although, I always thought the speed limiter was a sensor located on the transmission? You sure of this?
the car started today for about 5 minutes then it died. i don't know if there is a relation this but every time i try starting the car i get so much pressure on my gas tank. i have to wait for a couple of hours before it will start again and it will only stay on for a couple of minutes.lsxavier wrote:i have a 95 240 se. i put a turbonetics turbo kit and after installing the car wont start. it just try to start and when i put a little gas it will die.i have spark, the timing is right. i check the injectors and their good. what else is there to check? i did the auto to manual swap also but i didn't change the ecu. is it posible the car wont start cause i have an auto ecu?any feedback will be greatly appreciated.
