after purchasing a '96 I30 discovered that...
klei
1- windshield pump does not work(should i replace the pump or could it be an electrical problem, fuse, cables etc)2- can not open trunk door using key or remote control.(have to use the release button at drivers door)3-gas pedal gets stuck and have to press hard to get it moving(could the cable be rusted?)4- car pulls back when driving at 60 miles/hr @ around 2000 rpm.also accelerator indicator moves slightly up and down when stopped.feedbacks are appreciated. Thankyou!forgot to mention that I do really like the car.pictures coming soon..
maxhopper
Car: 02 Maxima SE 6spd
1 Probably the pump.
2 check the trunk latch. There is a small lever below the latch that can be moved up and down. i believe that lever should be in the up position.
3 Check for obstructions binding the accelerator cable both inside the car and in the engine bay.
4 Not sure on this one.
MattB
Car: 2001 Infiniti I30A
When you say accelerator indicator do you mean the tachometer? This would indicate idle flutter.
klei
yes, I meant tachometer.
MattB wrote:When you say accelerator indicator do you mean the tachometer? This would indicate idle flutter.
