after market rims void warranty? help!
All things Altima Coupe.
vi3t89
Car: NISSAN ALTIMA 2.5s
okay well i brought my car into the stealership today because the wheel lug is loose , i got my tires balanced and when they were puttin the bolts back on 1 lug screwed in but it shakes and its lose the guy at the shop told me its internal and bring it to the dealership to get looked at i bring it in and the tech tells me its not under warranty because i put 20' aftermarket rims on but the problem is internal wdfs? can someone correct me if im wrong? the guy who balanced my tires told me hell fix the problem for free if the dealership isnt going to but he told me its better the dealership fix it because it was an internal problem ?
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Sounds like they stripped the stud. The stud is the threaded rod that sticks out of the hub that the lug nut screws on to. You have 5 studs on your a/c. They are easy to cross thread or strip if you don't put the lug nut on correctly. Once this happens the stud has to be changed. The stud actually connects internal to the hub its connected to. You have to take the hub apart to remove the stud and replace it. Hes right, it is internal, and Nissan would have the best take on doing it. However, Nissan is never going to cover it because the other guys shop is the one who caused the damage. Take it back to that guy and have him replace it. If he really doesn't know how to do it, he will refer you to someone else to do it, and his shop will cover the expenses. They guy is just trying to save a buck. Hope this helps
vi3t89
THANKS HELPS ALOT! only problem is i duno which shop messed it up lol the one who put the rims on or the guy who balanced it the guy who balanced it was the one who said it was messed up after so LOL i uno cuz it was fine from the first guy so im assuming its the second guy
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
If you have another dealer near by, you can put the stock wheels/tires back on, and pay that other dealership's service department a visit.
vi3t89
LOLS i was thinking the same thing the guy who owned the rim shop told me to try that but he was joking he said hell take care of everything cuz hes not satisfied until i am and so on so yeah
nightrain
Car: 2008 3.5SE
vi3t89 wrote:okay well i brought my car into the stealership today because the wheel lug is loose , i got my tires balanced and when they were puttin the bolts back on 1 lug screwed in but it shakes and its lose the guy at the shop told me its internal and bring it to the dealership to get looked at i bring it in and the tech tells me its not under warranty because i put 20' aftermarket rims on but the problem is internal wdfs?
Let's not 'lose' sight of the source of this problem.
20" Rims are the Devil's Wheels.
Modified by nightrain at 12:00 AM 5/21/2008
