Leo2005 »
https://forums.nicoclub.com/leo2005-u72744.html
Wed Feb 29, 2012 7:09 pm
You can buy any aftermarket unit and you will be able use back up camera since it's got regular yellow RCA output then you can use steering wheel buttons with specific adapter which you can find literally anywhere like eBay, crutchfield, abt etc. but you won't be able to use satellite radio since it's got completely different plug and most likely you won't be able to modify it. Regular radio antenna will be used with Motorola plug adapter which is available on the same resources. And last but not least you will need special harness that allows you to use the factory amps if you have Bose system installed.
