After market HU
izzy973
Car: 1998 Qx4
I was wondering on a 97 qx4 do you need a dash kit for a double din deck if it came stock with Bose system? I know you need a special wireing harness.
fueler
Car: 2 Nissan's
2 BMW's
ive seen bose come in both double din and single din. mine was a double din and it looks very standard, no kit needed, just the trim that comes with the deck. i switched to single din, just needed to buy the lower pocket. and fits snug
izzy973
Car: 1998 Qx4
Yea the deck in there is a big brick with cassette tape in it.. i was told at a audio store i needed a custom dash kit made out of fiberglass to run the double din and i don't see why when the deck is the same size? he was going on about something how the bose deck has angles in it and they'd have to make the kit. i see a few people have instaled double din decks no problem...
fueler
Car: 2 Nissan's
2 BMW's
ya definitely you dont need no fiberglass. stereo shops can be funny sometimes (PS i'd stay away from that one that told you that stuff) i also had the brick with cassette deck, when i removed it, my pioneer single din slid right in and even bolted in to the stock screw holes. all i needed was a $20 lower pocket to take the place of the hole that will result from going to double din >> single din
izzy973
Car: 1998 Qx4
So long story short I should be able to get a double din deck in no problem without a special kit just use the 1 it comes with?
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
izzy973 wrote:So long story short I should be able to get a double din deck in no problem without a special kit just use the 1 it comes with?
It will mount fine but you'll have a gap around the deck. Easy solution is to just take a piece of 1/8"-1/4" Black ABC plastic and cut it to fit as a bezel. I mounted a sub control and antenna switch in mine. Here's a pic of my old deck with just the sub controller:
