The OEM cruise control is operated via steering wheel-mounted controls, so your OEM kit would probably have to include a new wheel. One would hope the airbag in your existing wheel would fit the new wheel, but if not, that'd be another $500 or so for a new airbag.yerrago wrote:They don't but it would be nice to get an OEM kit and convert the S to one with cruise control. It shouldn't be that difficult considering that the car has a modular design and that a cruise control module can be added.
Unfortunately, I not sure it's compatible with the Versa. The ad refers to a "servo," short for "servomechanism"...the device that actually ties onto the throttle arm of a normal car to physically control the car's speed.indus49 wrote:This is a possibility... http://www.jcwhitney.com/autop...10101
I'm not sure what you mean by "knob." The standard Versa cruise control has two buttons and a rocker switch for set/coast and resume/accelerate. Sure, it could be done with a separate control box, but where would you put it on the wheel? Hard to add on such a box without it looking really ugly and tending to get in the way...and I don't think Nissan would want to put their name on it.yerrago wrote:The "fly-by-wire" feature would actually make it easy- but only for Nissan - to add cruise control as an option. The kit would consist of a replacement control "knob (for lack of a better term)" for the steering wheel (not a new steering wheel) and some kind of electrical actuator that would hook up with existing wiring assembly to enable cruise control.
Still not so simple. You still need a cruise computer, which needs to be wired into the ECU (easy if there's a pre-wired loom, but that may not be the case on the S)... and also to the clutch. Those of us with the SL that have had the clutch-slip problem know that there is a hydraulic switch tied into the clutch assembly that deals with the cruise control. Not exactly "plug and play" material.rwanttaja wrote:
Conceivably, the stock wheel has all the wiring and mounts for the cruise control system in place, under the plastic covers for the steering wheel "arms". If this were the case, Nissan would just have to ship out the replacement arms with the appropriate bezels in place for the cruise control switches.
Ron
