After Market BlueTooth Mic Install
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Elf
Car: Nissan Versa 1.6 with Auto and AC
Hey Guys I bought the Pioneer-FH-P800BT I want to run the Mic up to my sun visor. Does anyone know how to remove the headliner trim that runs from the Dash to the headliner? Is there a route you would suggest i run for the mic wire?
Thanks for any help you can give.
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
The A-Pillar finisher (what runs along the windshield) will just pull off. Pull the top portion first as the bottom is tucked inside the dash a little to keep the parts together.
Want to do a step-by-step install for us and I can add it to our tech section website debuting this year?
Shad0wXCalibur
Car: Nissan Versa SL Sedan
I had that same deck installed in my Versa. I put the mic on the steering column cover for best pick up. But I've had experience with mounting my wife's external XM radio to the top-left corner of the windshield with double-sided tape in her cars. It simply involved pulling off the a-pillar cover and fishing the wires through the dash. It's a little tricky but I've always managed it without having to pull the whole dash apart.
williamk10
Car: '07 Nissan Versa SL
thats how i did it when i installed my tweeters in the a pillar. just pull hard and the clips will come out.
Return to “Versa Technical Discussions”
