After I need your help nico.
J0SHYee
Car: 1991 240sx
2001 I30
After sanding down the wheels and priming them I discovered this.
My question is can I take it to a welding shop and get it fixed? Also if I just leave it and mount tires will it crack further? Thanks
Btw i posted in the wheels and tires section, no help at all so her we go my fellow 240 owners.
Modified by J0SHYee at 12:25 AM 11/9/2009
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
OH damn, it will definitely crack further, and i dont believe that would hold air for very long either. You may be able to get it repaired but usually once a wheel is stressed to the point of cracking its never the same.
sr20power
Car: S14 Zenki
Damn that doesn't look good! I wouldn't try mounting tires on that. You can try to weld that together and see what happens but I would get a new wheel.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
I tried getting a wheel welded that was cracked just like that. It ended up bubbling out every tire that I installed on it. Never really held air again and from the constant inflating, and deflating, it ruined the tire. Get a new wheel.
ashibah83
Car: 93 SUPA BLACK COUPE
what wheels are those? honestely it may not even be worth welding if you can get a replacement fairly cheap
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Not a welding shop. Take it to a wheel repair place. What they will do is drill out the end of the crack, grind down the cracked section then fill in the material and grind to match and check wheel balance.
J0SHYee
Car: 1991 240sx
2001 I30
Thanks for everyones input, im just going to take it to a wheel repair shop like you said above me. Thanks. mods you can delete if you want.
