clever240sx »
https://forums.nicoclub.com/clever240sx-u28216.html
Sun Feb 21, 2010 1:40 pm
It was not a ground issue. I had already checked every ground and replaced and added grounds, still didnt fix it. But good news i fixed the problem!After stripping the interior for the second time checking every wiring harness in the interior and about to pull the dash i thought i should double check the engine bay cuz we all know how big of a pain in the a** pullin the dash out is. Anyways i was taking apart the relay box behind the drivers headlight(the ac, acc, etc relay box) and i had noticed the wiring harness going to that relay box was covered in white and blue crap. I took the platic loom off and the wiring harness was all coroded. But the wire that was coroded all the way through was the thicker gauged white wire that goes to the acc relay. Rewired that and everything turned on. For once i can actually say that i loved hearing that "240sx door chime" come on!!
But it makes since because there is no stock air box which leaves a hole and when it rains water gets in and sits where that harness lays and after time it will corode if not covered properly. After all the car does have 203xxx original miles on everything.
But thanks everyone for helpin me out!!
