180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Jan 15, 2005 5:17 pm
compression test it. another thing, if your cam is off a tooth, might want to check it and make sure. pop the top, and roate the crank around till everything's lined up. If one of the cams are off, you can see it as you turn the crank. There'll be two links that will line up eventually, if they never line up, you've got chain issues.
