Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Feb 27, 2004 7:46 pm
i don't think the FPR will help too much. check all your injectors with a stethascope or take a screwdriver and put the tip to an injector and the handle to your ear and listen. you're trying to find an injector that is busted. the injectors will run full open when they freeze (at least in most cases, this seemes to happen). a frozen injector makes a sound like it's having a heart attack or no sound at all. a normal injector will sound like a steady thump thump that's not too loud.
i'm just offering one possibility, but I have heard of FPR's going out when the pump has been upgraded. If that's the case, I would replace it with a nismo FPR just because of cost issues (the nismo part is relatively cheap and easier to obtain than a stock unit)
