yellow_jacket wrote:Just because the piston is at TDC does not mean you are on the compression stroke. Try rotating the CAS 180 degrees.
should i turn the gear on the cas 180 degrees from where the FSM tells you to set it and then insert it or
should i set it according to the FSM insert it and then turn the cas 180 degrees?
Also should i just line up the cam sprockets with the intake cam at about 10 oclock and the exhaust cam at about 12 oclock with cylinder #1 at tdc and set the cas according to the FSM and then insert it?
Tell you the truth i'm confused on what to turn 180 degrees....i get people telling me to turn the crank 180 and some that say turn the cas....someone please elaborate.
