after burnout car runs like crap, PLS HELP ASAP (sr20)
djsonic
last night i did a burnout and right afterward the car started running like total crap, when giving barely any throttle it runs fine , it revs and idles pretty much normal too. when giving it anything over barely any throttle , once boost comes on it sputters misfires loudly, i can feel it through the gas pedal. today i changed the plugs and that didnt do anything. (the old plugs were really loose, would that normally affect performance?)2 days ago i put in a walbro fuel pump, i rechecked my installation today and everything looked fine.
thanks alotsean
MODS:sr20det3" downpipe3" hks hyper exhaust3" test pipehks front mount intercoolermanual boost controller (14psi)300zx tt fuel filterwalbro 255lph fuel pumpeibach,tokico suspensionpwr radiator w/ dual electric fans
Nathan
Did an IC coupling come loose? I would check that first and then move on.
djsonic
d
NISTECH
it sounds like air flow meter ,but you say it happens right when the turbo kicks in? maybe something happen to the turbo when you were pushing it.
djsonic
i dont think its the turbo, it spools and sounds fine, air flow meter would make sense, how do i go about checking itthankssean
NISTECH
there is a faq on it or its in nissan articals. if you have any probs with the procedure post back.
djsonic
nissan articles? im new to the board , whats that?
NISTECH
http://www.nissaninfiniticlub....t=MAF
go to this link and scroll down to the 4th post
proimport17
Car: motocross, baseball
The first post was probably correct. Recheck the intercooler piping to see if it came loose or developed a hole in it. You might also check the wastegate to see if for some reason it is holding boost off.
MarkEmark
Car: fully-built '95 240sx KA-T
Sounds like a boost leak to me as well. Mine would do the same thing when I had leaks (i actually had the coupling blow right off of the TB, twice...live and learn)
