i didnt, and i will try and bleed the brakesterry_240sx wrote:how did you know if the brake booster from the junkyard was any good?
did you test it or anything?
if it did work before, if i were you, i would try re-bleeding the whole system again.
nawEnjoiNismo wrote:Did you bleed the brakes at all after swapping?
id start with that one then first and see what you get. remember to do the brake farthest away from the cylinder then go to the next farthest...benarovi561 wrote:nawEnjoiNismo wrote:Did you bleed the brakes at all after swapping?
