Unnatural1 »
https://forums.nicoclub.com/unnatural1-u59065.html
Wed May 30, 2012 8:38 pm
That misfire, if driven too far, could very well damage an otherwise good cat. Misfires allow large amounts of raw fuel downstream to reach the cat. The temperature in the catalytic converter, as a result, will rise to the point that the substrate inside it actually melts down. If the Check Engine (MIL) light comes on and begins flashing, the PCM is detecting a misfire that can damage the cat in this way.
You may try fixing the misfire and clearing the code. After 10-20 miles of driving, rescan the PCM for codes and see if the PCM has run it's monitor tests. If the cat monitor is set you might be ok. Once the engine is sound and running smooth, readdress the P0420 code if it reoccurs.
Also, a bad coil pack can set various codes, depending on the car. The most common codes across the board are P0300-P0308. All of which indicate misfires on a particular cylinder, or random cylinders in the case of P0300.
~Brendan
Unnatural1 on Wed May 30, 2012 8:42 pm, edited 1 time in total.
