boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Tue Sep 06, 2011 10:50 am
You can follow the manufacturers suggestion, but those clutches weren't designed with new engines in mind nor do they mention breaking-in their clutches with brand new engines, so you're going to have to assume that they designed these clutches with the thoughts of engines that are already broken-in and used. Just go drive the thing as the clutch is not going to prematurely wear and void your warranty. Your engine is waaaay more important, so break it in properly and that clutch is going to have to get in where it fit in and hold on for the beat-down.
