Lopin18 »
https://forums.nicoclub.com/lopin18-u58480.html
Wed Mar 12, 2008 1:23 am
Well if u did the swap from auto to manual, Auto shifter has a trigger that deactivates when the car goes into PARK, when it deactivates the key release system unlocks and lets u push button and move the key to lock and remove....
So since I did a 5speed swap i had this problem that the key release NEVER got unlocked since i no longer can put my car into park and deactivate the trigger....
So... to the auto shifter there are 2 harnesses, one harness has (dahhh) cables which i cut, so i dont know what they did... BUT the other one has a Black plug that i actually unplugged from the auto shifter assembly, i started with the cables first, none of them did anything, and i started cutting the Plug`s cables, inmediately and i was halfway cutting the plug (cables joined due to the knife) i heard the lovely CLICK sound, so i cut it all, joined the 2 cables that unlocked the key release and voila its done i can push the button and release anytime since it never locks
IN resume, just look where the shifter used to be look for a harness with a black small plug with like... 4 cables in it, and cut it up and join the cables in pair until u get the click from the key release. (if u dont have those cables just start mixing them until u get the click! :P)
btw, this is when its a swap i dont know if the factory 5speed models has any harness in the shifter... they probably use something on the clutch pedal and brake pedal and not in the shifter or the neutral gear sensor from the transmission...
Good luck
OH YEAH, ill post pictures tonight
