95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Tue Nov 08, 2005 6:47 am
where in the setup is the boost gauge reading from? before or after intercooler? also, what do you mean it won't make any power past 10psi? there is also the possibility that your MBC's spring is only good for about 10psi, and that turning it past that just shuts off the flow entirely or almost entirely, thus blocking the wastegate from opening much or at all, in which case the turbo would put out as much boost as it physically can, but all the while blowing really hot air.
