Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Thu Apr 12, 2012 11:55 am
a vacuum leak would lean out your idle. Do a boost leak test to see if you have any vacuum leaks, then move onto exhaust. An exhaust leak is pretty loud, you should be able to hear it unless you're running open downpipe or something.
Speaking of which, if you are running open downpipe, how close to the end is the sensor? Any fresh air will cause a bad reading.
