compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Wed May 25, 2011 7:06 pm
First off, I hate to say it but get rid of those iridiums they can cause tuning issues. Gap them to 30-32. Bpr7e v power plugs are good for 20+psi so you could easily get away with 6 heat range, plus copper is a better electrical conductor than iridium . I'd also ohm check your coils, that will tell you if there good. Also check your o2 sensor voltage while cruising to see if it matches your wideband, maybe your ecu is getting incorrect information. Also, since you are speed density now, it is very important that your speed sensor, cts, and tps are all working properly. Another thing is who tuned the car? If the coolant temp changes or even outside barometric pressure changes and isn't tuned for those various conditions it will cause problems. That's why mafs is usually preferred for tuners as far as reliability and simplicity. Hope this info helps.
