dont go cheap...safin wrote:any ideas?
Cruising you can actually go leaner than that as long as your under vaccum. When we tune we tune for 15.5 A/F cruising for gas milage. At 0 pressure we aim for 12.5-13 A/F and under load we tend to aim for 11-11.5 and use timing to make the power. Safer A/F is more important than trying to make power by leaning it out to far.cheapscheisst wrote:14.7 is the ideal a/f ratio when cruising
Lambda 1 for gas is 14.7 A/F, so 12.0 A/F would be 12/14.7 = 0.82 Lambdasafin wrote:how would all those numbers would translate into lambda?, im planning on going the cheap way by just using a bosch wideband O2 sensor with the autometer air/fuel gauge that i have
This is true. Also leaner is NOT meaner as most people would think. Their is an acceptable "window" of lean-ness, after that you start losing power and hurting your motor. I usually tune for 11-11.5 a/f (on boosted applications of course). You'd be surprised as to how rich you can actually go without losing power. I've seen af's as low as 10.5 before ANY power was lost.Blown240sx wrote:Safer A/F is more important than trying to make power by leaning it out to far.
The loss of power or pushing it beyond the limits is also true with Ignition timing. What people dont understand when they tune is Power falls off way before knocking occurs and thats what gets people in trouble with tuning. Thats why a Dyno is necessary. You can get a good A/F on the street but true tuning requires some dyno time.stewie8apie wrote:
For best gas mileage I tune for around 15-16 a/f. It's not lean enough to hurt anything. You could actually go leaner than that under highway "cruising" conditions.
To answer your question though, you should be fine cruising with the af's that you are, but your wallet must hate you!
Istilldo wrote:I know that, but I can't find when I'm not pressing gas(on a gear) why does my injectors still open? anyone got an idea?
