Blackened »
https://forums.nicoclub.com/blackened-u81358.html
Fri Oct 03, 2008 5:19 am
I have a mixture problem for a few months, and I tried a lot of stuff but I couldn't make any difference.
the problem exists only on cold start. When I start the engine, it first goes 16-17 AFR; I touch the gas pedal, and I set the rpm at 1100 and wait like that. And when the engine gets warm, I begin to move the car. It happens at that time, when I move the car and take it to 2nd gear, afr suddenly falls to 10!!!. Car starts to choke? And sometimes it stops. I found the answer by hitting gas pedal. If I hit the gas pedal 4 or 5 times, and rev up to 4000rpm, it goes normal, and it never happens again till I stop the engine.
I changed my injectors, fuel pump, fuel pressure regulator, but it didnt make any effect. Also I cleaned up my MAF sensor. What else should I do ? Should I change my MAF ?
