trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Thu May 15, 2003 5:52 pm
It's not really hard, you tap into the 02 sensor wire like the directions say.... then wire it up to ignition power, ground, light power, and ground again. You can get a wiring diagram of the ECU (search Google, one will come up) and tap into the 02 sensor wire there. Ground, just find a ground point, and illumination you can find behind the radio, it's the orange wire on any aftermarket stereo, not quite sure what on stock.
