afc2 plus 550 injectors
get_up_mark
Car: 98 240sx se
im running an afc with 370cc injectors but i feel the need for more power and my injectors are maxed out. will my afc2 be able to handle 550cc injectors or possibly bigger once i decide on my power goals? also ill be running the z32 maf if that makes a difference.
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
The most the safc II can handle with a stock ecu is 550cc.
lilskyline240
Car: 90 240sx w/ rb30det
how are u running a different MAF with an SAFC?
znelson
Car: 1992 240SX
lilskyline240 wrote:how are u running a different MAF with an SAFC?
A ton of people run n60/n62 maf's with the safc for control. I run a j60 w/ the safc2 actually.
lilskyline240
is it compatible with the SAFC?? im not very familiar with the SAFC so thats why im asking
znelson
Car: 1992 240SX
Ya, thats what the AFC allows you to do. You can dial in the In/Out settings depending on what maf and injectors you are using
Florida240sx
You can run larger than 555. But you might get into idle and gas mileage issues. 555 are the max you cna have full control over. With a different engine you might be able to ocntrol higher or lower. Depending on what your CP ratio is and your ignition system. With tomei 555cc I was able to idle in the 14's and had perfect a/f ratio at all rpms.
