180fan wrote:have you set the MAF adjustment in the AFC to z32? Also remember to have 1 in 1 out, set for z32 instead of sr20det and it should be fine. If you're still having trouble, check your wiring.
Exar-Kun wrote:that works with the old s-afc, too I take it (I have the s-afc, not the s-afc2)???
that would be nice. running a 550cc injector setup with a Z32 and I dont have to spend the 600 dollars for a JWT re-write..-chet
