Jeff240sx »
https://forums.nicoclub.com/jeff240sx-u610.html
Thu Mar 20, 2003 5:01 pm
PJ - Yeah. I was running the Tial spring. If you can't find one, or need one, I don't need mine anymore.Yes, I did run with stock injectors, fpr, pump, ecu, absolutly no fuel control. No problems at all.The problem is that a O2 sensor works in the range of 0-3V, and the blinky light gauge runs on 0-1V. A wideband O2 runs 0-5V, as do the expensive A/F gauges. One caveat to going WB O2 is that they are meant for tuning, and you'll be buying a new ($150+) WB O2 sensor just about every year.So, my final though... save the $60 on the blinky-light gauge, and buy an EGT, or pyrometer. It will tell you the same thing. Hotter than usual = lean, cooler than usual = rich. They are more accurate, also.Also, I was running 93 octane. 92 is good too, and in Cali, 91 will work for stock fuel system vs. 4.35psi.-Jeff
