madbouncy »
https://forums.nicoclub.com/madbouncy-u15966.html
Sat Feb 18, 2006 11:23 am
It depends, do you want aerodynamic as in very little drag or do you want downforce. Sealing off the bottom is a very good start and for venting the hood, I'd say you're better off having it vent out behind the front wheels. If you put a spoiler on your car and you vent out your hood, all you're doing is helping the airflow seperate from the body sooner. Also, if you might want to put something at the rear of the roof to help keep flow attached. Anywhere oyu have an angle greated than about 10-15 degrees the air is going to stop following the body. The coupe has a sharp fall off for sure. The most important part of stopping drag is going to be how the air rolls off your rear end.
