stevesrt4 »
https://forums.nicoclub.com/stevesrt4-u34158.html
Fri Jan 27, 2006 11:54 am
Got my AEM wideband in today and to me, from a guy who is coming from the srt platform i am lean. I called enjuku who at the time had scott on the other line. I told them that i am running 9.5lbs and my a/f ratio threw the powerband is 13.5 ta 13.7 witch to me is lean, like the car should'nt be running right lean. in the neon that kinda a/f ratio would couse a break up in the power band. scott told enjuku which told me that, that was a normal reading for a stock sr ecu at 9.5lbs and i was safe. but to me that just seems lean. i think for my own self i will try to swap out this 94ser o2 sensor with the 300z turbo one and see if it makes a diffrence. that or i'll just stick the stock one in the hole and see how it runs... if that does'nt work i'll turn the boost down a couple lbs if the computer pulls fuel and makes the same a/f then i know for a fact that, that is what there soupose to run at... car pulls very hard for what it is, and does'nt buck or skip a beat. if i did not have the wideband to tell me what the a/f is i would not even be worried. I'd be beating the hell out of it.... Please post your thoughts. Am I ok to beat the piss out of her? or do I have a issue.....
Also the motor came with a adjustable wga and i can see from the wirring the ecu had a piggyback on it of some sort. could the guy have swapped out the wheel inside the turbo (yea right I'm not that lucky) or done something that would require more fuel than the stock set up + walbro pump? ...thanks, steve.
