I got mine in but it was a HUGE pain in the a**. The disc was a little bent too so I tried to straighten it out as much as I could so it didn't touch. AEM S2 btw.
My tach signal was also dead, I can walk you through it but I rather not type it out if you want to callYellow4g63 wrote:Ok got my car to start after messing around with the injector timing to get it right. My tach doesn't work tho wtf?
First thing.... Set the TPS wizard, then get it running and do the tying sync wizard.OutToWinPAHC wrote:What tune is it? Is this just the TPS based start up cal provided with the AEM?
