AEM users: New CAS wheel not firing
bmadd2402
Car: Twin Turbo-shaft UH-60L, 1992 RB-240sx
I am installing my new EMS. I changed out the cas wheel today, and tried to fire it up with the stock ecu, and it wouldn't start. I pulled the cas off, and spun the shaft by hand, and only heard 1 injector click per rev. Will the AEM CAS wheel not work with the stock ecu? if it should, does anyone have any ideas?
Bluefire
the AEM Cas wheel only works with the AEM unit....
eh?
get a stock cas just incase.
timlush
Car: S13 Coupe
So with the AEM unit, you HAVE to get this wheel? What is the price?
bmadd2402
comes with.
eh?
timlush wrote:So with the AEM unit, you HAVE to get this wheel? What is the price?
The EMS has issues reading nissan 360 slot CAS so they issued a custom cas wheel to fix the problem. So cars have the problem, while some show no issues for some reason. It's a serious issue that can lead to a blown motor.
raremotive
Car: 04 Infiniti G35
you can also rig up a crank angle sensor reading from the crank, and use the CAS for ignition.
