Ok guys,
We have a buch of the AEM Tru Boost Gauge/Electronic Boost controllers available also.
We cant post the price, so email me at
[email protected] if you are interested.
Model # 30-4350
Brand new units from AEM is a boost gauge with built in boost controller. No longer will you have to use 2 seperate units to monitor and adjust boost. Much like their popular Uego Wideband gauge, this Tru Boost gauge uses LED's and digital readouts to help you monitor boost levels and uses 2 buttons on the front of the gauge to set boost levels and adjust the controller options.
Specifications are as follows:
Complete stand-alone boost controller gauge On-board pressure sensor included for boost levels up to 29 PSI Two user selectable units Peak boost memory User selectable over boost alarm with overboost shutdown User scaleable bar graph display User selectable waste gate delay for quick turbo spool External warning lamp driver No external interface required for programming Easy to install harness allows for quick and easy installation Boost hose and fittings included for easy hookup to on-board pressure sensor Another great thing about the gauge is it includes 2 different colored gauge bezels and faces - black or white. Mix and match them to get your desired look.
Thanks,
Ken
