AEM><INJEN....(intake)
le_ryan
Car: Mazda3
91 Nissan 240SX SR
do u perfer AEM.... ....INJEN...or other, and why,the brand with the most votes is the intake i will be installing onto my 91 240sx KA.
InsanityInc
AEM. Cheaper, K&N filter. Difference between the SRI and the injen CAI have been shown to be nil on a dyno. Probably because of the amount of extra piping needed for the CAI.
aesic
Car: '91 S13
Wouldn't the dyno results be a little off because on a dyno, there is no air rushing by the car? The CAI won't get the cold air, and thus you wouldn't see the difference or its benefits unless on the road. Just a thought.
-aesic
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
any aftermarket intake unless made of plastic, isnt going to make any more power than a cone filter and adapter setup. the reason for the this is heat absorption. the metal piping of an AEM or Injen intake heats up much more than the stock platick/rubber pipe.
my $0.02...i actually lost a few hp after installing my Injen.
aesic
Car: '91 S13
USDM240 wrote:any aftermarket intake unless made of plastic, isnt going to make any more power than a cone filter and adapter setup. the reason for the this is heat absorption. the metal piping of an AEM or Injen intake heats up much more than the stock platick/rubber pipe.
What if you wrap it in heat wrap?
-aesic
InsanityInc
aesic wrote:Wouldn't the dyno results be a little off because on a dyno, there is no air rushing by the car? The CAI won't get the cold air, and thus you wouldn't see the difference or its benefits unless on the road. Just a thought.
-aesic
They put a very large fan in front of the car when running it on a dyno, enough to simulate airflow. Since if they didn't, your car would overheat.
And increased heat absorption isn't really an issue because your intake charge is WAY hotter than your underhood temperature, by a few hundred degrees. Hell, if anything, the increased conductivity will probably slightly cool your intake charge.
Tulsa_S-13
Car: 1991 SR 240sx
USDM240, Aluminum does absorb heat very quickly, however I disagree with you on the air heating up so much that there is actually horsepower loss. Granted that the air does heat up slightly I don't believe it is in the intake tubing long enough to actually heat up substantially. It's kind of like sliding ice across a hot surface for a short period of time, yes the ice melts slightly but not enough to make a big difference.
And I wouldn't say the piping heats up much more than plastic, it heats up quicker than plastic.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
6 posts......3 votes.....come on people..and it doesnt help that its a tie right now......please vote your prefrance, it will help alot.....thanks
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
"The power is in the pipe"
AEM = 2.5", Injen = 2.75"
What's better for YOUR setup...? Depends on the level of modification.
...but a cone filter is no better than a K&N drop-in filter.
See here - Cone filter versus cone filter + Injen intake pipe DYNO:
- Brian
240marcuSX
Car: E34 525i
E46 M3
man thats a pretty nice gain for just a piece of pipe, i thought that the stock 240sx intake piping was pretty decent already. perhaps ill look into getting a injen pipe, do they sell just the piping without the filter?
All_Motor_KA
Car: 1989 240sx SE
The stock pipeing is FAR from decent. Very very tiny to say the least. I bought an ebay intake and I dropped in a K & N cone filter on it. Works great and was pretty cheap. As far as AEM vs Injen, I've always heard pretty good things from Injen so I would prolly choose them.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
your telling me I can get like 4hp just by changing out the stock plastic pipe?!?! I did not think I would get any gains except looks...
le_ryan
Car: Mazda3
91 Nissan 240SX SR
wow ! just what i needed, specs!, thanks for the diagram!...im definatly in the direction of INJEN.......thou it would be nice to see an AEM diagram....well its still tie game.......need more votes
InsanityInc
:: orion :: wrote:"The power is in the pipe"
- Brian
Ehhh. That seems to imply that they replaced the stock intake and airbox/filter with the injen system. Not just the pipe.
JimmyMethod
Car: 97' 240SX SE
Stock intake = restrictiveStock piping = restrictive
sunnys14
Car: S14
theyre both the same to me
ians-ka
i would go for the aem myself, i have it. the dynos on the aem intake are showing 8 horses over stock and 10 ft-lbs. it has to do a lot more with removing the stock pipe with the baffles and eliminating the resonator box under the stock pipe more than anything else. but the obvious increase in pipe diameter doesn't hurt either.
:: orion ::
InsanityInc wrote:Ehhh. That seems to imply that they replaced the stock intake and airbox/filter with the injen system. Not just the pipe.
The dyno notes do imply that...but if you read the article (or the series of 4 articles on this car), you'd see that they put on a cone filter as their first mod.
www.KA24DEvelopment.com/dyno_charts.html - Look for "Installment 1", and it shows what they did first.
And the quote "the power is in the pipe" comes directly from that issue of SCC.
- Brian
le_ryan
Car: Mazda3
91 Nissan 240SX SR
im gonna let the poles run a little while longer, just to see how well INJEN does , ill choose the winning brand on the 20th on staurday
Scooby24
Car: 01 BMW 330CI
Is 4hp gain and 4 ft. lbs REALLY worth the 150 bucks or however much for an Injen?
Just buy a cheap ebay intake.
You can't even feel 4hp.. and that's good for MAYBE 5/100ths of a second in the 1/4 mile.
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
yeah... i bought a cone filter and an adapter and popped it on my stock intake... seems to work fine... in reality intakes arent worth the money.... put that 150 bucks into something usefull like a nismo power brace or towards the beginnings of a turbo kit/swap etc
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
I think in my opinion that if you use the 2.5" AEM you will do just fine....If you want colder air to your engine don't bother buying cold air intakes, the longer the tube the more velocity the intake is creating "through a TWICE as LONG PIPE", minimizing top end HP.....If you want to achieve the cold air effect with a short intake such as the AEM or injen you can do what is called coolant bypass, that is as close to cold air as you will get weither you have a long or short intake.I say stay with a short intake, if you live in Cali get the AEM, if you live anywhere else get the Injen short Intake, followed by the coolant bypass...Cold air intakes is just more expensive and unecessary pipe for the "wannaBE" gains that it will achieve.AEM and Injen are both excellent companies, don't accept imatation!!!
wilfonzo
Car: s14
is there a write up or anything on this "coolant bypass" i did a search and came up empty... the pics are great but i cant figure out what is going on
InsanityInc
basically there's a coolant line running through the bottom of the throttle body so that in extremely cold climates, your TB doesn't freeze shut. This is obviously bad for intake temperatures, as it's going to make the throttle body extra hot. So basically you just run the coolant line directly to where it goes to after coming out of the throttle body, thus removing the TB from the coolant system.
wilfonzo
Car: s14
awesome, thanks alot!
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Well I own an INJEN CAI and I am going to have to stick with works for me. As for buying a cheap CAI from Ebay I would be careful. My friend went that route and tired to make fun of me about how much more I spent on my INJEN than he did on his ebay crap. When he got it in the mail and asked me to help install it I turned the other cheek and decided to help him since he is a fellow 240 enthusiast. Anyhow after we were halfway thru the install it turned out that he didn't have every piece he needed and in my opinion it didn't fit as good as my INJEN does either. So after all that headache I made him re-install the stock unit and drive his own car to the home depot to retireve the extra hose and fittings. My point is you get what you pay for, always. Just know what you can go cheap on and what needs to be paid full price for!
Bigvinnie
InsanityInc wrote:basically there's a coolant line running through the bottom of the throttle body so that in extremely cold climates, your TB doesn't freeze shut. This is obviously bad for intake temperatures, as it's going to make the throttle body extra hot. So basically you just run the coolant line directly to where it goes to after coming out of the throttle body, thus removing the TB from the coolant system.
Couldn't of said it any better..
InsanityInc
oh, also be aware that your hood will flatten part of the pipe with either the AEM or injen system.
ddgsxr504
What the hell are you talking about?? The hood will flatten partof the pipe. If that were the case the damn pipe would have a dent in it the next time you popped the hood! That has never happened to me or any other person I know!
BadMojo
Car: 2007 Mazdaspeed 3
ddgsxr504 wrote: What the hell are you talking about?? The hood will flatten partof the pipe. If that were the case the damn pipe would have a dent in it the next time you popped the hood! That has never happened to me or any other person I know!
Yeah, I must admit that we've all probably seen dozens, if not hundreds of pictures of KA's with Injen or AEM intakes. Everybody and their dog seems to have at least an intake. In all of those photos, I've never seen a scratched up, crushed intake pipe. Maybe I'm just misunderstanding this whole thing...
I'll put my AEM in this Sunday, slam the hood three or four times and then take some pictures.
